IPB
> Problems selecting JSON Object, Also, no debug output
Mihawk90
post Dec 24 2016, 20:42
Post #1
Member
Group: Full Members
Mp3tag Version: 2.80
Hey there.
Currently trying my hands on a WS Script for fanart.tv. So far I've been able to get the data from the API to load (yay), but I'm not sure if I'm doing it right. There is no output when I use json_object, so I don't know if it accessed it, since it also doesn't error out when it doesn't find an object by that name.
But first, here's the current code:
CODE
# Mp3tag Tag Source for FanartTV API
# Search by MusicBrainz Release-Group ID
# This file should be stored in your tag sources sources directory
# %APPDATA%\Mp3tag\data\sources
# and requires Mp3tag v2.64 or above.
[Name]=Fanart.tv
[BasedOn]=www.fanart.tv
# Append personal API Key, more info about them here:
# https://fanart.tv/2015/01/personal-api-keys/
[IndexUrl]=http://webservice.fanart.tv/v3/music/albums/%s?api_key=738e7602362418fda8158f44fb12e6df&client_key=
[IndexFormat]=%_url%|%preview%
[SearchBy]=%MUSICBRAINZ RELEASE GROUP ID%
[ParserScriptIndex]=...
# I N D E X
debug "on" "C:\Users\Tarulia\AppData\Roaming\Mp3tag\debug_fanarttv.txt" "5"
json "ON"
# API returns 404 on error, no need to read out error message as Mp3tag errors out on 404
# get the actual image
json_select_object "albums"
json_select_object "8f4d4f05-36ed-3c81-86a7-aae2a03b1520"
json_select_array "albumcover" 0
json_select "url"
outputto "coverurl"
sayrest
And the Debug Output (note that I commented out the select_array and following, see below)
CODE
Total output to process:
"name": "3 Doors Down",
"mbid_id": "2386cd66-e923-4e8e-bf14-2eebe2e9b973",
"albums": {
"8f4d4f05-36ed-3c81-86a7-aae2a03b1520": {
"cdart": [
"id": "8618",
"url": "http://assets.fanart.tv/fanart/music/2386cd66-e923-4e8e-bf14-2eebe2e9b973/cdart/away-from-the-sun-4e484652567b2.png",
"likes": "2",
"disc": "1",
"size": "1000"
"id": "61074",
"url": "http://assets.fanart.tv/fanart/music/2386cd66-e923-4e8e-bf14-2eebe2e9b973/cdart/away-from-the-sun-509e55644d26d.png",
"likes": "0",
"disc": "1",
"size": "1000"
"albumcover": [
"id": "190047",
"url": "http://assets.fanart.tv/fanart/music/2386cd66-e923-4e8e-bf14-2eebe2e9b973/albumcover/away-from-the-sun-56cc1174dfda4.jpg",
"likes": "2"
Output : ><
Line and position:
Script-Line : 26
Command : json
Parameter 1 : >ON<
Output : ><
Line and position:
Script-Line : 31
Command : json_select_object
Parameter 1 : >albums<
Output : ><
Line and position:
Script-Line : 32
Parameter 1 : >8f4d4f05-36ed-3c81-86a7-aae2a03b1520<
Output : ><
Line and position:
Total output:
output["CurrentUrl"]= "http://webservice.fanart.tv/v3/music/albums/8f4d4f05-36ed-3c81-86a7-aae2a03b1520?api_key=738e7602362418fda8158f44fb12e6df&client_key="
output["Output"]= ""
output["Error"]= "<OK>"
Note that I hardcoded the second json_select_object for testing.
Now I have multiple problems:
1. When I use ParserScriptAlbum instead of ParserScriptIndex, no log file is created. At all. Also I have no idea what's the difference really, but I assume I actually need the ParserScriptAlbum since it's probably showing the result of the selected album?
2. When I use the script like that, there is no log file created, at all, unless I comment out the json_select_array and the following lines.
3. In the real world I can't actually hardcode the MBID into the json_select_object function, but I haven't been able to use the actual ID in any way. I tried using %MUSICBRAINZ RELEASE GROUP ID% and %s both with and without quotes, but according to the debug output the value isn't used. Is there even a way of using that variable? If not, well.. I got a problem smile.gif Can I use json_foreach on the albums object or does it not work on objects, but only on arrays?
4. Is it normal that there is no Output when selecting an object? I have no idea if the selection actually works or not. Is there a way to get a serialized version of the selected object into the output?
Hope someone can give me a hint and/or get me on the right track from where I can continue on my own smile.gif
Thanks in advance
Go to the top of the page
+Quote Post
Mihawk90
post Dec 28 2016, 18:30
Post #2
Member
Group: Full Members
/bump
If all else fails I'll probably just go ahead and re-write the whole thing using the usual parsing functions, but I'd like to do it the "right" way (when we already have JSON functions, why not use it huh? smile.gif )
/Edit:
QUOTE
Solved this one... It was a little late I guess smile.gif Parsing the IndexUrl won't work with the ParserScriptAlbum I guess smile.gif
/Edit #2
QUOTE
Well... yeah... solved that one too. Must be the only scripting language where the first element of an array is actually 1 and not 0 tongue.gif
Currently I have this then:
CODE
json "ON"
outputto "coverurl"
json_select_array "albumcover" 1
json_select "url"
sayrest
Problem is, there's nothing in the debug output that really helps me. Selecting anything doesn't give any hint of what it selected, or if it even selected in the first place. It doesn't even tell me when it couldn't find the object we're looking for (for example searching for "alsfsdfbusodfudshms" doesn't return an error, it just does nothing).
/Edit 3
Using json_foreach "albumcover" works but I don't really get why... I don't see why iterating over "every" (in this case 1) array-element would work, but using array element 1 directly wouldn't...
Problem is there are a few cases where there are multiple images. I want to build an Index at some point, but that's another project for another day. I just want to make it work for now smile.gif
/Edit 4
As a sidenote, as I was playing around without using the JSON functions I tried joinLines until the end of the input, but using an arbitrary large number doesn't work, leaving the argument empty doesn't work either, and there doesn't seem to be a way of getting the number of lines in the input. Is there even a way to do that?
PS: When there's a stray json_foreach_end it appears Mp3tag just crashes (I had it when I had the json_foreach and tried json_select_array again but forgot to comment out the json_foreach_end)
This post has been edited by Mihawk90: Dec 29 2016, 00:51
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 18th December 2017 - 02:19
