IPB
> Set TRACK in scripts HACK., Doing 'set' fn doesn't have any effect.
stevehero
post Apr 25 2017, 02:04
Post #1
Member
Group: Full Members
Mp3tag Version: 2.84
If you place this at the end of your script...
CODE
set "TRACK"
You will still get the TRACK in the main tag info window resulting in it tagging the TRACK TAG.
There's a solution by placing 500, for example (Which should be enough), |'s at the end of your script like so in conjunction with # set "TRACK" (Optional) if you place that option at the end:
CODE
    outputto "track"
    say "||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
# set "TRACK"
I'm pretty sure this may be a bug. But, I'm not certain. Anyway, here lies a solution.
Can someone test and report back if it's okay?
This post has been edited by stevehero: Apr 25 2017, 02:07
Go to the top of the page
+Quote Post
Florian
post Jul 1 2017, 19:17
Post #2
Developer
Group: Admin
Mp3tag Version: 2.85h
QUOTE (stevehero @ Apr 25 2017, 03:04) *
It's not. Can you check if you're really using
CODE
set "TRACK"
to clear the content of the "TRACK" output buffer in your script (without the #, which would comment out this line).
Kind regards
– Florian
+Quote Post
stevehero
post Jul 2 2017, 00:09
Post #3
Member
Group: Full Members
QUOTE (Florian @ Jul 1 2017, 19:17) *
CODE
set "TRACK"
Kind regards
– Florian
I was sure that this was occurring with a previous version.
I 100% had the TRACK set.
Seems fine now.
+Quote Post
pone
post Jul 26 2017, 00:49
Post #4
Member
Group: Full Members
Mp3tag Version: 2.59b
Easier and working fine with my discogs scripts:
CODE
# Delete TITLE Field
set "title"
outputto "title"
say "|"
# Delete TRACK Field
set "track"
outputto "track"
say "|"
I did quite a lot of testing until I had it going. I think I remember it's important to use the two command blocks in this order to get both working. And to use it at the very end of the script.
+Quote Post
stevehero
post Jul 26 2017, 13:04
Post #5
Member
Group: Full Members
QUOTE (pone @ Jul 26 2017, 00:49) *
CODE
set "title"
outputto "title"
say "|"
set "track"
outputto "track"
say "|"
So the initial bug find is there you think?
I've been busy so haven't had time to source the script which I had problems with. Think I may have deleted it.
CODE
set "TRACK"
doesn't work
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 18th December 2017 - 02:15
