IPB
> SayRegexp Problem, Non fixed widths inside lookaround
stevehero
post Jul 1 2017, 14:36
Post #1
Member
Group: Full Members
Mp3tag Version: 2.84
Using this regexp: (for websource parsing)
CODE
sayregexp "(?<=\"artists\" data-aid=\"(\d+)\">)[^<]+ ", " "trk-list-cont"
Code for testing (using mt_ttt.png)
CODE
I'm trying to seperate the artists from the following code example.
CODE
<a href="/artist/artist 1" class="artists" data-aid="392805">Artist 1</a><a href="/artist/artist 2" class="artists" data-aid="3805">Artist 2</a>trk-list-cont
To result in:
CODE
Artist 1, Artist 2
As you can see the digits are the non fixed width. Only it returns an Invalid lookbehind error. Which is down to the regexp language used by Mp3tag (I think), so.. .
1. Any workaround for this?
2. What regexp language does Mp3tag use as .NET regexp can take advantage of non fixed widths inside lookarounds.
Go to the top of the page
+Quote Post
Florian
post Jul 1 2017, 19:13
Post #2
Developer
Group: Admin
Mp3tag Version: 2.85h
1. Maybe KillTag can be of help here?
CODE
killtag "a"
killtag "/a" ", "
2. Mp3tag uses boost::regex which doesn't support non-fixed widths inside lookbehind.
Kind regards
– Florian
+Quote Post
ms6676749
post Jul 2 2017, 10:35
Post #3
Member
Group: Full Members
Mp3tag Version: 2.75
Or maybe do a regexpreplace for the data-aid value to make them all uniform if you don't need those identifiers anymore. Could be numbers or letters, whatever you choose. Here, I'm going to swap those digits with a string of zeroes:
regexpreplace "(class=\"artists\" data-aid=\")\d+" "${1}00000"
CODE
to
CODE
<a href="/artist/artist 1" class="artists" data-aid="00000">Artist 1</a><a href="/artist/artist 2" class="artists" data-aid="00000">Artist 2</a>trk-list-cont
Now, you have don't have non-fixed lengths to worry about.
This post has been edited by ms6676749: Jul 2 2017, 10:41
+Quote Post
stevehero
post Jul 2 2017, 11:27
Post #4
Member
Group: Full Members
QUOTE (Florian @ Jul 1 2017, 19:13) *
CODE
killtag "a"
killtag "/a" ", "
Kind regards
– Florian
Thanks. I've never actually had to use killtag before. I'll try see if I can make use of it. I've used the solution as below.
I suppose there's no furture plans to migrate to .NET regex?
QUOTE (ms6676749 @ Jul 2 2017, 10:35) *
CODE
to
CODE
Thanks. Yeah, that's exactly what I've been doing for years. Just wanted to see if there was a headon solution.
My solution: (is to enable fixed length lookbehind)
CODE
regexpreplace "(\"artists\" data-aid=\")\d+" "$1albumartist_fix"
This post has been edited by stevehero: Jul 2 2017, 11:38
+Quote Post
ms6676749
post Jul 4 2017, 19:53
Post #5
Member
Group: Full Members
QUOTE (stevehero @ Jul 2 2017, 11:27) *
CODE
Yeah, yours makes the most sense when targeting %albumartist%.
This post has been edited by ms6676749: Jul 4 2017, 19:53
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 18th December 2017 - 02:20
