IPB
> Possible Error in Official Discogs.src v1.06, Section "Media Type" not working
michael_funk
post Oct 4 2017, 15:16
Post #1
Member
Group: Full Members
Mp3tag Version: 2.43
Hi!
When I use Discogs.src to get the tags for Discogs Release ID 996990, the output to the MEDIATYPE field is "CD". I would expect it to be "CD, Album, Reissue", since the code in Discogs.src explicitly selects the values in descriptions.
# Media Type
outputto "MEDIATYPE"
json_select_many "formats" "name" ", "
sayrest
json_select_many "formats" "descriptions" ", "
ifnot ""
say " "
endif
sayrest
The data structures (as shown in mp3debug.txt) are:
"formats": [{"qty": "1", "descriptions": ["Album", "Reissue"], "name": "CD"}]
So my question is: How do you correctly reference the values in the descriptions array?
Michael
Go to the top of the page
+Quote Post
Florian
post Oct 14 2017, 11:02
Post #2
Developer
Group: Admin
Mp3tag Version: 2.85h
Hi Michael,
many thanks for bringing this to my attention — it's indeed not correct. A good way to also output the descriptions (while at the same time making clear that it's not the actual format) would be:
CODE
# Media Type
json_foreach "formats"
    json_select "name"
    sayrest
    json_select_array "descriptions" -1 ", "
    ifnot ""
        say " ("
        sayrest
        say ")"
    endif
json_foreach_end
What do you think?
Kind regards
– Florian
+Quote Post
michael_funk
post Oct 16 2017, 10:04
Post #3
Member
Group: Full Members
Hi Florian,
thank you for your reply and the solution.
What do you mean by "... (while at the same time making clear that it's not the actual format) ..."? I just generated a new debug.txt - the format is exactly as displayed in the original post. Or did I get something wrong here?
Your solution works quite nicely and I think, it should become part of the next official discogs.src. I'll keep an eye on the output of the new code while tagging other records.
Many thanks and best regards,
Michael
+Quote Post
Florian
post Oct 16 2017, 10:14
Post #4
Developer
Group: Admin
Hi Michael,
QUOTE (michael_funk @ Oct 16 2017, 11:04) *
It's just a little bit different, but it's only a minor change: I've but the format descriptions in brackets to distinguish the actual format from the descriptions
CD, Album, Reissue
vs.
CD (Album, Reissue)
QUOTE
Great smile.gif Thanks again!
– Florian
+Quote Post
michael_funk
post Oct 17 2017, 11:43
Post #5
Member
Group: Full Members
QUOTE (Florian @ Oct 16 2017, 11:14) *
CD, Album, Reissue
vs.
CD (Album, Reissue)
Oh, THAT you mean! Yeah, sure ... I thought you were reffering to the format of the input.
I also extended the original script to fill the tag MIXARTIST if present.
In the following discogs release I found interesting info on the musicians that played on an individual track:
https://www.discogs.com/Miles-Davis-Live-Ar.../release/396240
If you would like to adapt the official script, here is my suggestion:
CODE
json_select_many "extraartists" "name" ", "
ifnot ""
outputto "MIXARTIST"
set "tmp_join"
json_foreach "extraartists"
sayoutput "tmp_join"
set "tmp_join"
json_select "role"
ifnot ""
sayrest
endif
json_select "anv"
ifnot ""
say ": "
sayrest
saynewline
else
json_select "name"
say ": "
sayrest
saynewline
endif
json_foreach_end
say "|"
else
say "|"
endif
I placed this right after the "artists" section in the tracklist loop.
Best regards,
This post has been edited by michael_funk: Oct 17 2017, 13:22
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 18th December 2017 - 02:17
