IPB
> How to install Tag Sources on macOS, split from 15726
aurelienvm
post Oct 6 2017, 06:47
Post #1
Member
Group: Members
Mp3tag Version: 284a
Go to the top of the page
+Quote Post
Florian
post Oct 6 2017, 07:44
Post #2
Developer
Group: Admin
Mp3tag Version: 2.85h
QUOTE (aurelienvm @ Oct 6 2017, 07:47) *
On macOS, Mp3tag's settings are stored at
CODE
~/Library/Application Support/de.mp3tag.Mp3tag_<some number>/drive_c/users/Mp3tag
and you copy the tag source into the
CODE
data/sources
folder.
Kind regards
– Florian
+Quote Post
aurelienvm
post Oct 6 2017, 08:20
Post #3
Member
Group: Members
Hello. I do not have "de.mp3tag.Mp3tag_ <some number>" in library ... sad.gif
This post has been edited by aurelienvm: Oct 6 2017, 08:22
+Quote Post
aurelienvm
post Oct 6 2017, 08:28
Post #4
Member
Group: Members
And after ? how to start the search with the itune store? thank you so much smile.gif
+Quote Post
Florian
post Oct 6 2017, 08:49
Post #5
Developer
Group: Admin
I've moved our conversation to a separate topic to keep the iTunes Web Sources discussion on topic.
You're probably looking in
CODE
/Library/Application Support/...
and not at
CODE
~/Library/Application Support/...
which is the Library folder in your user folder, e.g.,
CODE
/Users/Aurelien/Library/Application Support/...
If you don't see the "Library" folder in your user's home directory, you can probably navigate to it via
Finder > ⇧⌘G
and then enter
CODE
To install a Tag Source, simply download the archive from the respective topic on the forums, extract in (in case it's a *.zip file) and copy the *.src file to the folder mentioned above:
CODE
/Users/<Your User Name>/Library/Application Support/de.mp3tag.Mp3tag_<Some Number>/drive_c/users/Mp3tag/data/sources
Kind regards
– Florian
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 18th December 2017 - 02:20
